Text Driven Lookup Table
mark.j.eaken
mark.j.eaken
i am trying to create a lookup table where i can type in the serial number into the Families Type and have it change parameters. or are lookup tables really only ND driven? can lookup tables be driven some other way?
iainsavage
Autodesk help says:
Notes:
  • The size_lookup function provides the ability to look up numerical values only.
  • The size_lookup function is intended for instance parameters. If you want to use tabular data to define types with unique values for each type, see Creating a Type Catalog.”
