I HAVE A LINKED MODEL WHICH CONTAINS SEVERAL BUILDINGS. WITHIN EACH BUILDING ARE SEVERAL UNITS DEFINED BY AREAS AND CONTAINING MULTIPLE ROOMS. I HAVE SMALL SCALE VIEWS IN WHICH I NEED TO TAG THE AREAS. I ALSO HAVE LARGE SCALE VIEWS IN WHICH I WILL TAG THE INDIVIDUAL ROOMS.
TLRD: LINKED MODEL IS MULTI-BUILDING, MULTI-UNIT RESIDENTIAL. INDIVIDUAL UNITS ARE DEFINED BY AREAS. I NEED TO TAG AREAS/UNITS IN VIEWS.
SO MY QUESTION: WHY DON'T AREA AND AREAS FUNCTION MORE LIKE MECHANICAL SPACES?
Solved by SimonWhitbread. Go to Solution.
The short answer is Areas are aimed at early project design where the Architect may need to see Gross floor Areas, predefine shop units / or as in your case, units in a building and - I'm guessing here - It was never anticipated that areas would be needed for MEP design.
That said, you could override the view properties to display the tags in the LINK file:
And Schedule the Linked areas:
It's a workaround, but might help.
Not going to lie, I kinda forgot I posted this. But it would seem like this option should work. I think we resorted to manually inserting text to tag the spaces.
