Revit MEP Forum
Structural in MEP
2 REPLIES 2
353 Views, 2 Replies
Structural in MEP
Can i draw web trusses, etc in Revit MEp 2012? I am making a quick model and want to show some structure.
I have trusses etc but when i try to place them in the model all i get is an error message cant create this kind of element in this view in the current model.
2 REPLIES 2
CoreyDaun
It appears that you cannot create Structural elements in Revit MEP 2012. However, if you have certain Families (like beams) that you want to place in the project, you can open the families and change their Category to Generic Model, and load and place them in the Project. Once placed, you can edit the Family and change the Category back and reload it back into the project. I can't say exactly how well this will work, though.
in reply to: CoreyDaun
Short answer - No.
If you need structural elements you either need to obtain a copy of RST and model them in their or create the family as a generic model and use that. I think I tried Cadastrophe's idea some time ago when I had this problem and I don't think it works (although my memory could be failing me!!). Unless you really need it to be a structural element (you can still clash detect generic models but need to remember that is the category not structural framing)  I would stick to generic models.
Forma Design Contest
