Specify Circuit Information pop-up
tkendrick
Message 1 of 8
tkendrick
I've wondered this for many years, it's really minor, so I've never taken the time to try to figure it myself.
Does anyone know what parameter settings for electrical connectors drive the "SPECIFY CIRCUIT INFORMATION" pop-up window.
Just now, I connected a 208V panel to a 480-208 transformer and I did not get the above pop-up.
I then connected the transformer to a 480 panel and I DID get the above pop-up.
I know I have some electrical devices (fixtures) that also behave this way, but not all of them. I imagine it has something to do with how the electrical parameters are set (type/instance?)
Again, this is minor, not really an annoyance, just an extra step. Mainly just curious what the specific parameter setting might be, so I can decide if it's worth changing.
Use this link to tell Autodesk about features you need:
Replies (7)
Message 2 of 8
kadmonkee
it might be based on the Distribution System being used in the project for that particular piece of equipment in your project along with how families are created.
we have used shared and family parameters to allow for quick changes to different voltages within 1 connector in a family
other options are to have 2 connectors designated in the family with different voltages so it pops up when circuiting begins
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 8
It's the part type in the family editor, I believe.  I've only ever seen that pop up appear in association with circuiting junction boxes.
Message 4 of 8
fabiosato
If the Number of poles and Voltage parameters linked to the electrical connector are set to instance ones, this window will pop up.
Fábio Sato
Message 5 of 8
tkendrick
Yes! I think that's it. I looked into my transformer family, it's voltage was set to Instance, when changed to Type, I did not get the Specify Circuit Info.
Good to know.
Message 6 of 8
perry.lackowski
@fabiosato, what determines the voltages that appear in this list? I have our panels set up with instance parameters for the voltage and number of poles, so we see this dialog box when we create the power circuit for the panel. However, our new project also has a voltage class of 220V. We set up the voltage and distribution system similar to a 208-delta or a 480-delta.
We're able to set the panel's parameters to 220V, 3-Pole, and Revit lets us assign the 220V distribution system.
However, when we click the Power button, this Specify Circuit Information dialog pops up, and it does not contain an option for 220V under 3 poles.
Are we going to be forced to make the voltage a type parameter in order to get around this?
Message 7 of 8
sragan
Apparently you don't get this option unless you add 127 Volts to your voltage definitions, and then add a 220/127V 3 phase 4 Wire system to the distribution definitions.
But once you have done that, you can select 220V when starting a new power circuit, and then you can connect it to you r delta panel.
Message 8 of 8
perry.lackowski
@sraganThank you, that did the trick!
