Revit MEP Forum
solve duplicate mark warning
20 REPLIES 20
Message 1 of 21
Zaatra
20377 Views, 20 Replies
HI EVERY ONE, HOW I CAN SOLVE THE DUPLICATE MARK WARNINIG ?
20 REPLIES 20
Message 2 of 21
in reply to: Zaatra
Under the manage tab, you see the Inquiry panel. There is a button named Warnings.
By clicking on that you are ableto see all the warnings. You will see a warning named: Elements have duplicate 'Mark" values. You can filter all the elements that have duplicate values and renumber the marks in the properties.
Another way would be to write a script in Dynamo that checks elements for duplicate values and renames them according to a certain predefined value.
Message 3 of 21
in reply to: Zaatra
You can create a schedule of the category, add Mark field to see the duplicates and renumber them.
Tags (1)
Message 4 of 21
RobDraw
in reply to: Zaatra
IMHO, there is no reason to resolve it. It's just an arbitrary number and duplicates can be ignored without any detrimental affects on the model.
Rob
Message 5 of 21
Zaatra
thank you for answer, but i have 800 warning , i install free trial element renumber but this software can only renumber the wire and cable tray
for daynmo can you give my matirial or video to learn it please?
Message 6 of 21
Zaatra
in reply to: ToanDN
thank you this solution is aplicable to me in another project but this project have 800 warning
Message 7 of 21
Zaatra
in reply to: RobDraw
i know that but sometimes it effect the speed of rendering of project
Message 8 of 21
in reply to: Zaatra
If you really don't need the Mark value and only need to get rid of the warnings then group the schedule by Mark, unitemized, type a number in the cell then delete it. That will clear all the Mark value and in turn, clear tge warnings.
Message 9 of 21
in reply to: Zaatra
This is a simple dynamo script that rewrites the Mark parameter with the Element ID for all elements visible in the active view. It's a custom node from the Bakery package. You can find a lot of information about Dynamo on Youtube. I suggest installing the Bakery package as well, as this will add a lot of functionality to Dynamo.
Hope this helps you out. If not, let me know and I'll see if I can help you out.
Message 10 of 21
fabiosato
in reply to: Zaatra
In Revit 2018, in the Dynamo player I have seen a free routine to do this.
Fábio Sato
Message 11 of 21
I am trying to get this duplicate mark warning message because I don't want the structural framings to have the same Mark value in it's instance parameters. Each Mark has to be unique. I tested in a revit architectural sample project and made a schedule with 2 fields (Family and Mark). Then I set the Mark for 1 beam at 100 and the other also 100, but I don't get the warning message...
Do you have an idea how to display this message?
Message 12 of 21
Message 13 of 21
in reply to: ToanDN
Hello Toad,
Could you upload a little screencast or a screenshot of this. Since I can not  do it by your text instruction. Once I do have all my doors with mark, I do select all but by the time I try to set 1 number, they do not change,
Thanks in advance.
Message 14 of 21
asWAPL9
I am having a weird bug. I get the duplicate type mark value warning, however my elements are not duplicates!!! it keeps on happening it is very annoying. how can this be?
Message 15 of 21
iainsavage
in reply to: asWAPL9
You’ve probably got two types in a family, both with the same Type Mark.
As one if the solutions above create a schedule withType and  Type Mark as fields, sort by Type Mark then by Type and you’ll see the duplicates.
Message 16 of 21
iainsavage
PS: extremely unlikely that this is a “bug”.
Message 17 of 21
asWAPL9
in reply to: iainsavage
two types, type 1 vs type 2. type 1 HAD value "x1" in the type mark parameter, but no longer. now it has "x2"
Type 2 has value "x1" in the type mark parameter.
warning appears as soon as i write that "x1" -duplicate type marks.
been working with this software since 2012, pretty sure its either a bug, or a software error.
Message 18 of 21
RobDraw
Share the file for verification.
Rob
Message 19 of 21
iainsavage
I did a Google search and couldn’t get any hits for any similar posts so maybe its rare or unique to your system. Maybe you should raise a support case with Autodesk.
Have you been getting this same error since 2012 or is it something which just recently appeared?
Message 20 of 21
asWAPL9
Unfortunately I cannot because of confidentiality reasons. will try to replicate it in a test project.
