As I am looking at the Technical School sample files located here, I am noticing that the Architectural / Structural models and the MEP model are NOT coordinated. After re-positioning the project base points in all three models to the same location (at intersection of grids H and 10 -- by the way, why aren't these points already in the same location in the models???), I linked the models together using "Auto - Project Base Point to Project Base Point" and the result is concerning. It appears that the architectural and structural models are (for the most part -- there are some elements not corresponding) in alignment properly, however the MEP model does NOT match the modeled conditions in the A & S models. See images below. Why is Autodesk providing sample models that are not coordinated and not modeled in a way that represents an integrated design? What am I missing here? Are there updated models that I am just not seeing for download? Can anyone shine a light on why this has happened to these models?
Autodesk has been perfect in every other aspect. Not sure how they didn't catch this. Your thoughts would be better served on the product feedback page or you can try the ideas page to get it fixed.
Good luck.
It seems that the models were not well coordinated at the beginning, or MEP is using and older version or the architecture model.....
These are things that must be fixed in the very beginning of the process, now it may demand a lot of work...
Fábio Sato
Have you tried to download the files and do nothing and try to link them as shared coordinates? thanks
This would not make a difference. As you can see from the images that I posted, the plans themselves are not coordinated...they do not match.
Does that fact interfere with doing any of the tutorials? It's been a long time concern that the OOTB content is not adequate in a number of ways. Does this revelation really surprise you? Is it going to affect the way you use the software?
If you want to bring this to Autodesk's attention and suggest that they fix it, there's the product feedback page or the ideas page where this thread is more appropriate.
