Rotating Tee pipe fitting
n_mouhamed
Message 1 of 9
n_mouhamed
I am facing a problem with MEP, i want to rotate that pipe fitting 33.02° using the rotate command but i am not able to do that. Does anyone know the solution how can i solve this issue?
Replies (8)
Message 2 of 9
Sahay_R
Are you trying to rotate the family instance vertically or horizontally? If vertically - Edit the family. Make sure that Always Vertical is checked (I know, it sounds counter-intuitive!)
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 9
n_mouhamed
I tried both with and without "Always vertical" but nothing changed. Qnd qs you see in the SS i wanted rotate it 33.02° but it doesnt change the angle.
Message 4 of 9
iainsavage
Your screenshot isn't very clear - which part is not rotating to the 33.02 angle? It looks as though the tee has rotated?
Message 5 of 9
n_mouhamed
 I want to rotate that part as you see in the SS
Message 6 of 9
iainsavage
You've obviously been able to rotate it somehow to get it into its current position.
What prevents you from rotating it further?
Do you get an error message? If so what does it say?
If you upload the family someone could examine it to see what the problem might be.
Message 7 of 9
n_mouhamed
The issue this is the model that I received, I  wanted to changed the angle but i am unable to do it. I uploaded the family.
Thank you in advance.
Message 8 of 9
iainsavage
The fitting doesn't work when included in pipe routing options.
It also doesn't work when placed manually (doesn't break into pipe):
It has been set as "Workplane Based":
Untick Workplane Base and tick Always Vertical and it will work.
Message 9 of 9
mari.shimode
Hi @n_mouhamed, how are you doing? Please reply if you still need assistance. If you have solved the issue, please click the Accept Solution button on a reply you find useful so that others who have the same question can find the information easily. Thank you.
Mari Shimode
