rotated wallparts - wrong dimension in schedule
binder.bernhard
Message 1 of 1
binder.bernhard
Hello!
I've stumbled upon a problem which gets quite annoying:
I create ventilated facades in revit by creating walls and splitting them into parts to make the sheeting elements. these elements get into a schedule to get manufactured.
This works pretty good. until the wall is not horizontally aligned. in such cases the scheduled dimension is off. I can imagine where this orginates from (as the technical beckground), but I'd really need the right dimensions in the schedules. attached you'll see an example, hope it's clear.
Is there a way to fix this?
Replies (0)
