Revit MEP Forum
Revit Generic family not visible in Mech Elevation
5 REPLIES 5
AkhildJTZCU
1213 Views, 5 Replies
Inserted a generic Revit family to my project. The family is visible in the mech floor plan as attached. (000)
But in the elevations, the object is not visible.  The screencast is attached. (111)
5 REPLIES 5
in reply to: AkhildJTZCU
Have you check visibility/graphics overrides in the family?
I think the view specific display are on only for plan/RCP.
yurikim
Thank you for your posting @AkhildJTZCU
Also check in the view, if generic family has been ticked in Visibility/graphics overrides dialog.
Visibility and Graphics - Essential Skill
Yuri Kim
Product Support Specialist, AEC
ennujozlagam
set you detail level to FINE and see if helps. thanks
NimeshJ
Hello @AkhildJTZCU ,
As I can see you have started a new project, can you please check if these elevations are correct?
I mean with Level 0 and Level 1. Please check if they are properly located.
Secondly, I can provide you easy solution. While on 0-Mech layout Go to View Tab -> View Template -> Create Template from Current View -> *Name it* . Now go to 1-Mech layout, Go to View Tab -> View Template -> Apply Template Properties to Current View -> Select *Name it*.
This should solve your problem. Make sure you check you view range.
Let me know if this works or not.
AkhildJTZCU
in reply to: NimeshJ
Thanks for that. Some level thing and offset error.
Forma Design Contest
Technology Administrators
