Revit 2020 VG Revit links selects first in list
darrylhouston9788
darrylhouston9788
Hi, a minor bug in 2020. In the Revit Links tab of VG when I am playing with the Halftone / Underlay / Display Settings & Apply button on some of the models, the first linked revit model keep selecting itself. So when i click another models I get the error stating I should only select 1 at a time. See attached pic.
I am clicking the red boxes - then Revit is selecting the 1st in list (Green) and giving me the error.
I am running Revit 2020.2.1. Anyone else having similar issues?
PavelAnd
Hi @darrylhouston9788 . Yes, after clicking "Apply" in VG my Revit 2020.2.1 also selects the selected document link and the first one. But if you click "Select none" then the selection will be removed and you will be able to select the links again normally and continue to change the settings. Or you can remove the selection by pressing "Ctrl" and select the first link.
Best regards, Pavel Plotitsyn.
fabiosato
It seems that you have more than one instance linked in your file.
Please click on the plus sign to expand and check if you have more than one.
Fábio Sato
