Hi all
I've written a script dynmo to retrieve element locations and place non-hosted family instances in the same location. However, I can't find a method to automatically delete the hosted family after placing the non-hosted family in the same dynmo code.
Louis
Please mention Revit version, especially when uploading Revit files.
elements.delete should be available in recent versions of Revit/Dynamo (I want to say since 2021?) as a standard library node, and available through the archi-lab package for versions before that.
I don't know about Dynamo but we do this exact thing in C# for un-hosting our Support Families from Fabrication Parts Pipe.
I don't have access to the source code but it can be done.
One problem I have with our code is it actually deletes and replaces the Support in the same place. This means you lose any Tags and dimension's etc.
If I was to get this changed I would move the Instance say 10mm in the Z axis with disjoin ticked. Then move the instance back to original coordinates and rotation. It will then maintain Parameter values.
