I have a R21 BIM project that some folks can open just fine whereas others at our company can't and have never opened the project. All hardware and R21 patches vary for those who can and can't open the project. It takes those that can open the project around 1-2 min to open. For those who can't, can leave Revit open for 2 hours and it never gets past a certain percentage on loading a link. The project is only 500ish MB in total links and all.
Below is a list of things I have tried to no avile. At the time of this post I am currently reinstalling from a Clean install. Does anyone have any tips on how to remedy this issues?
Tried:
Note: Revit stores paths for up to 15 models.
If access has not been restored, then use the following steps to complete a Disk Clean-up
10-Jan-2023 08:24:02.661; File: Open
' 6:< Connecting session [$37cbfe81] to Worksharing Log [C:\Users\USERNAME\AppData\Local\Autodesk\Revit\Autodesk Revit 2021\Journals\journal.0237.txt]
' 6:< Additional IP address/name found for host XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
' 6:< Additional IP address/name found for hostXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
' 9:< ::56:: Delta VM: Avail -717 -> 134209566 MB, Used +2 -> 1136 MB; RAM: Avail -6 -> 106568 MB, Used +1 -> 1226 MB
' 9:< GUI Resource Usage GDI: Avail 9775, Used 225, User: Used 234
' 9:< Server-based Central Model [identity = 55a1ec01-f19c-4b0d-8e95-0894a2e14552, region = "US", path = "BIM 360://202243 New River Electrical/202243 New River Electric.rvt"]: init
'10:< Connecting session [$870a78cf] to Worksharing Log [C:\Users\USERNAME\AppData\Local\Autodesk\Revit\Autodesk Revit 2021\Journals\journal.0237.txt]
'10:< Additional IP address/name found for host XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
'10:< [TKY] readUT file is dummy
'10:< [TKY] readER file is dummy
'10:< EP::readDeltas 0 to 0 ignored; caller said refreshAllElements
'11:< [TKY] readEP file is dummy
'10:< [TKY] readWorksetCheckouts file is dummy
' 9:< DSI::loadPermissionsFiles error
' 9:< [TKY] loadPermissionsFiles erasedUT 0, erasedEP 0, erasedWC 0, erasedER 0
' 0.155377 9:<<loading DocumentStorageIndex
10-Jan-2023 08:24:02.956; File: Open
' 7:< Connecting session [$1e1dbd8f] to Worksharing Log [C:\Users\USERNAME\AppData\Local\Autodesk\Revit\Autodesk Revit 2021\Journals\journal.0237.txt]
' 7:< Additional IP address/name found for host XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
'10:< ::57:: Delta VM: Avail -717 -> 134209566 MB, Used +1 -> 1136 MB; RAM: Avail +1 -> 106576 MB, Used +1 -> 1227 MB
'10:< GUI Resource Usage GDI: Avail 9775, Used 225, User: Used 233
'10:< Server-based Central Model [identity = 55a1ec01-f19c-4b0d-8e95-0894a2e14552, region = "US", path = "BIM 360://202243 New River Electrical/202243 New River Electric.rvt"]: init
'11:< Connecting session [$ac1a8aa4] to Worksharing Log [C:\Users\USERNAME\AppData\Local\Autodesk\Revit\Autodesk Revit 2021\Journals\journal.0237.txt]
'11:< Additional IP address/name found for host XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
'11:< [TKY] readUT file is dummy
'11:< [TKY] readER file is dummy
'11:< EP::readDeltas 0 to 0 ignored; caller said refreshAllElements
'12:< [TKY] readEP file is dummy
'11:< [TKY] readWorksetCheckouts file is dummy
'10:< DSI::loadPermissionsFiles error
'10:< [TKY] loadPermissionsFiles erasedUT 0, erasedEP 0, erasedWC 0, erasedER 0
' 0.156132 10:<<loading DocumentStorageIndex
I also got a few API errors, three in total but they seemed not relevant.
Solved by damcclellan52Z5M. Go to Solution.
Thanks for your suggestion and reply!
I had spliced files from a user who could, to mine as I was not able open the project. Some of the steps were a bit different than what I followed in my docs but after the clean uninstall of Revit and the Desktop Connector I was able to open it on my end. If the two other folks who can't open it aren't fixed post clean uninstalls, I will give you link a shot.
Able to get the other user who also could not open the project to open it after these steps.
