Pneumatic system
Pneumatic system
bri47744
Pneumatic system
bri47744
what is the correct way to model and define pneumatic systems such as those used for industrial mechanical actuators?
As far as I have been tried so far, the use of the mechanical system is not entirely correct and does not allow the definition of a delivery pressure, which is the main parameter that needs to be inserted.
HVAC-Novice
Unless Autodesk introduces a new category (like they did for Plumbing equipment a while ago), you have to use something that is "similar" or a create sub-category. They most likely won't add a decent pneumatic pressure calculation feature since that is a niche application, but you never know.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
