Piping Annotation
Piping Annotation
williams_cory_a
Message 1 of 15
Piping Annotation
williams_cory_a
Is there a way to make the piping annotation read down to up so that its consistant. (see pic)
Cory
Replies (14)
Message 2 of 15
RobDraw
I don't believe there is a way.
Rob
Message 3 of 15
fabiosato
Set the check for Rotate with element in the tag properties.
Fábio Sato
Message 4 of 15
RobDraw
The image posted shows typical behavior when rotate with element is checked.
Rob
Message 5 of 15
BiMBoXiT
For me its working with the same option, Please see the snapshot  & let me know is it line with your requirements.
BiM BoXiT
Message 6 of 15
williams_cory_a
I understand its the typical behavior when rotate with component is selected. If this is the only way to make the annotation read bottom to top, is there a way to align it with the pipe? The annotation will not rotate and align with the angle of the pipe, so to be in the center.
Message 7 of 15
RobDraw
I don't understand.
Your image shows the tags rotated and centered. Your original question seemed to be about the tags on pipes that are at an angle greater than 90 and less than 180.
Rob
Message 8 of 15
Kelsey.S
Autodesk Support
Autodesk Support
Hi @williams_cory_a,
Did you get your question answered?
If so, please click 'Accept as Solution' on the posts that helped you so others in the community can find them easily.
Thank you!
Kelsey Skaug
Autodesk Technical Support
Message 9 of 15
williams_cory_a
Id like the tag to read from bottom to top in the centers of all the pipes
Message 10 of 15
RobDraw
You need to word your request more carefully. You won't like the results for pipes like this:
For the orientation that you exhibited in your image it is understandable but Revit doesn't do that.
Revit's pipe tag is slightly off center. You can edit it so that it is centered.
Rob
Message 11 of 15
williams_cory_a
I'm pretty sure I worded my request accurately. If you don't understand, you don't have to respond.
Message 12 of 15
RobDraw
Did you look at the image I posted?
If those tags read from the bottom up they would be upside down.
Be careful what you ask for and be sure about what you want before you ask.
I understand what you want but you are being too general in the way you are describing it and not taking into account all the implications. Think!
Rob
Message 13 of 15
williams_cory_a
From bottom to top, as in my original image. I cannot explain it like im talking to a child. Obviously I don't want it to be read upside down. Your responses are not helpful so stop commenting on my posts.
Message 14 of 15
RobDraw
Stop being so dense. You are oversimplifying your "request". Your issue is when a vertical pipe is past 90 degrees. You want the label to be rotated 180 degrees which technically is upside down when viewed from the bottom of the sheet.
At what angle between 90 and 180 would you consider it to upside down?
Rob
Message 15 of 15
fabiosato
Sorry to ask, I am not an english native speaking, and I would like to understand clearly your demand.
I understood that you need the tags to behave the exactly way of your picture, which, using rotate with the component does.
Is my understanding correct?
Or you want all tags oriented horizontally?
Or you need that the tags on the left side of your picture could be read on the opposite direction? This option is not possible.
Fábio Sato
