Matching level elevations from linked model
mthomas45
mthomas45
I'll admit to not being well versed in shared coordinates.
Upon linking in a model (auto origin to origin), I see the architectural levels are set to being with level 1 being at 100 feet.  When I copy/monitor these, they come in starting at 0 feet.  I'd like these values to match.  How should I approach this?
Edit the level type and try Survey Point for Elevation base.
mthomas45
This doesn't seem to have any affect.  Should I just move the linked model vertically up 100 feet?  I imagine there would be problems with that later on.
Did you acquired shared coordinates?
mthomas45
EDIT:  Ok, yes after linking, then acquiring coordinates, I'm able to copy monitor the level and then change it to survey point.  This matches the elevation.  Thanks.
ennujozlagam
try this and see if helps. thanks
ennujozlagam
sorry wrong post. thanks
