Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
pipes not showing properly
7 REPLIES 7
Message 1 of 8
venkatesan.d
404 Views, 7 Replies
when i draw pipe in revit it is not showing properly. how to corrdct it.
when i see it in 3d view, it shows jumping polygons.
7 REPLIES 7
Message 2 of 8
RobDraw
in reply to: venkatesan.d
Such simple questions are much better answered with a web search. There are plenty of tutorials and classes for the inexperienced and untrained. There are some Revit 101 things that you need to learn to get started.
Rob
Message 3 of 8
venkatesan.d
in reply to: RobDraw
so you don't know how to solve this issue?
Message 4 of 8
RobDraw
I do but there are resources that you aren't taking advantage of. You could have the information that you need and much more by now if you had done one simple search.
Rob
Message 5 of 8
RobDraw
Here. This should get you started on the right foot.
Click here!
Rob
Message 6 of 8
venkatesan.d
I find out the issue.
The Navis file which I have inserted is having some problem. that's why the pipes are showing like that.
I don't have architectural Revit file that's why the problem is happen.
May be you don't understand the issue I did faced.
Message 7 of 8
RobDraw
How could I have understood since you did not offer that information?
Good luck!
Rob
Message 8 of 8
iainsavage
I didn’t understand your problem either. Your screenshot was sort of meaningless - for future problems like this its better to share your model so that someone can open it and investigate. The fact that you were linking an NWD file is also relevant and should have been mentioned, especially since you’ve seen this post about NWD visibility problems.
We’re here to help (voluntarily) but we’re not psychic.
Forma Design Contest
