when i draw pipe in revit it is not showing properly. how to corrdct it.
when i see it in 3d view, it shows jumping polygons.
Such simple questions are much better answered with a web search. There are plenty of tutorials and classes for the inexperienced and untrained. There are some Revit 101 things that you need to learn to get started.
I do but there are resources that you aren't taking advantage of. You could have the information that you need and much more by now if you had done one simple search.
Here. This should get you started on the right foot.
I find out the issue.
The Navis file which I have inserted is having some problem. that's why the pipes are showing like that.
I don't have architectural Revit file that's why the problem is happen.
May be you don't understand the issue I did faced.
How could I have understood since you did not offer that information?
Good luck!
I didn’t understand your problem either. Your screenshot was sort of meaningless - for future problems like this its better to share your model so that someone can open it and investigate. The fact that you were linking an NWD file is also relevant and should have been mentioned, especially since you’ve seen this post about NWD visibility problems.
We’re here to help (voluntarily) but we’re not psychic.
