Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Pipe label not hiding pipe behind tag.
5 REPLIES 5
414 Views, 5 Replies
I want to tag a pipe and have the label hide the portion of pipe that is behind the tag. How can I change the settings to accomplish this?
5 REPLIES 5
williams_cory_a
After you label the pipe in the properties go to Edit Type select background > Opaque/Transparent
s.borello
Was going to chime in, but it looks like @williams_cory_a has your solution.
After clicking edit type I dont see the background option. this tag is suppose to automatically label system type and size. It would not be standard text.
s.borello
You need to edit the family_ then click the label, then edit type. Now you will be able to click transparent.
Thank you all very much for the help.
Forma Design Contest
