Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
PIPE ANGLE GETS CHANGED AUTOMATICALLY.
23 REPLIES 23
Message 1 of 24
Ajay_J_S
959 Views, 23 Replies
WHEN DRAWING THE PIPE IN REVIT THE ANGLE OF THE PIPE GETS CHANGED AUTOMATICALLY.
DON'T KNOW WHAT CAUSES THIS ISSUE... CHECKED THE FAMILY CONNECTORS ALSO
PARMETER OF THE FAMILY IS ALSO CORRECT I GUESS
Labels (2)
23 REPLIES 23
Message 2 of 24
iainsavage
in reply to: Ajay_J_S
Change to Use Any Angle if you don't want it to snap to set values.
Message 3 of 24
Ajay_J_S
THANKS FOR THE REPLY.
I HAVE CHECKED THIS ANGLE IN THE MECHANICAL SETTINGS ALSO STILL THE PROBLEM EXISTS
Message 4 of 24
iainsavage
Post a screenshot of your settings.
Please stop "shouting" in all caps.
Message 5 of 24
Mahmoud.Ziedan
@Ajay_J_S
simply in the fitting family the elbow .select the connector that should be the start of the elbow and from the conextual tab you have the possibility to assign as primary.and then link the two connectors together.
by the way you can differentiate between the primary connector and the others by the  X mark
Your question got successfully answered? Then just click on the 'Mark as solution' button.
src="https://autodesk.widen.net/content/fbz0l2onhe/png/autodesk-expert-elite-forum-signature-logo.png" >
Mahmoud Zeidan
BIM Manager/Mechanical Engineer
Message 6 of 24
iainsavage
in reply to: Mahmoud.Ziedan
That won't be causing this behaviour.
@Ajay_J_S please respond to my earlier request if you still want help.
Message 7 of 24
Mahmoud.Ziedan
Most likely the probem is with the fitting family.
As i can see whatever the angle is ,teh fitting is taking the same angle.
I recommend to upload the family here so i can have a look.
Mahmoud Zeidan
Message 8 of 24
iainsavage
I think the opposite, I think it's the pipe angle settings per my earlier answer, and the fitting is flexing to those angles, but since I was ghosted we'll never know.
Message 9 of 24
fabiosato
The point where both pipe lines intersect must correspond to the family origin.
By the image, your fitting family seems to be wrong.
Usually, I create the main connector pointing to the left and the angled connector pointing to the upper right.
Fábio Sato
Message 10 of 24
Ajay_J_S
Hi i have linked the connectors & made the one connector primary, the problem still exists
Message 11 of 24
Ajay_J_S
Sure will upload it soon
Message 12 of 24
Ajay_J_S
in reply to: iainsavage
what screenshots you require. let me know
Message 13 of 24
Ajay_J_S
hi there is no rotaion happened in the pipe fittings. the pipe keeps on changing the angle
Message 14 of 24
fabiosato
Can you share your family?
Fábio Sato
Message 15 of 24
Ajay_J_S
Hi, Here is the family file @fabiosato @Mahmoud.Ziedan Please have a look & share me your thoughts
Message 16 of 24
Ajay_J_S
Hi does anyone found any solution @fabiosato @Mahmoud.Ziedan  or any others
Message 17 of 24
iainsavage
Your origin (insertion point) is in the wrong place.
You need to adjust the geometry so that the intersection of the pipe centrelines is at the intersection of the CLR and CFB planes.
Message 18 of 24
Ajay_J_S
Will check & will share
Message 19 of 24
Ajay_J_S
HOW TO SET THE ORIGIN LIKE THE IMAGE PLEASE SHARE IN STEP BY STEP PROCEDURE
Message 20 of 24
iainsavage
Move all of the geometry, recreate any constraints and dimensional labels. Adjust dimensional values/formulas if necessary.
The attached document will help in setting up fittings from scratch.
Could you also please stop posting in all caps.
Forma Design Contest
Technology Administrators
