- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, Any one can help on this error, when I'm opening the revit project I faced the error to delete the elements.
once the delete elements is given, I got the some irregular changes pipe routing sometimes its happen to the that entire floor.
Warnings that I noticed from the report:
"1. The family is connected in a network and can no longer keep the connectivity. Disconnect the family from the network?
2. The duct/pipe has been modified to be in the opposite direction causing the connections to be invalid.
The first time & before it was completely open and fully loaded we worked two levels. After the Error & the delete elements, model was open, But now pipe was all over the place. It was running diagonal through multiple floors. It was outside the building. It was deep underground. It looked like a something happen in model. We have the backup model to fix this issues, but if we copy the old one I will lose all the annotations relates to this two floors. we have around 15+ live models to work in this project, this is the second model that we got the same error. to avoid this error happening in remain models what should I do. we were worked around 10+ live models nearly three floors in each model.
I decided the best thing to do was to manually adjust the problem pipes. So I deleted the bad pipe and re-modelled it. I'm worried that If I encounter the same issues in other blocks means remain 18 models, that will not be quite as easy to fix. And I'm worried that I will lose a lot of my progress. Or worse - the entire project. I also have modeled Pipes in the other floors on this same file like ground & first floor, I haven't noticed anything wrong with it or misplaced anywhere. it happen only on the two floors the what we modified.
Have any of you encountered an error like this? Is there an easier way to resolve this issues. Any help at all will be greatly appreciated.
My Project is cloud work-sharing model. and Build version is Revit-2019
BR
Laksh.
