Model Group element moved from our existing level
deepaklpjv
Observer Observer
deepaklpjv
Observer
Observer
Model Group moved from the existing location, but i cant bring back to the original location when i use the command place model group it showing the error i just linked the error image just find and give me a suitable solution which will be helpful for my projecterror.JPG
L.Maas
Where is the group coming from. created in the project or loaded in from external file?
As the error message indicates it has some constraints that does not allow it to be moved.
You can try several things (make sure to have a backup):
-Delete the group from the model and place it again
-Edit the group and see if you can find which element might be an issue. It could be for example a hosted element that lost contact which its host.
-Remove elements from the group and see if you can move the group then (repeat for several different elements inside the group)
-Ungroup and move the ungrouped elements (and then group again, if needed)
Louis
Please mention Revit version, especially when uploading Revit files.
