Pipe Error Coming from Mechanical Equipment
Hi all,
I have encountered this error, whereby the pipe coming from the mechanical equipment has some error when I run the interference check. (Photo attached). Not sure why..
Thanks!
RobDraw
"Some kind of error" doesn't tell us anything. If you are saying that the interference is the error then what is it interfering with and why is it an error?
Rob
I have attached the interference check report. It doesn't have any clashes, but yet Revit p
rompts a warning.
RobDraw
Your issue is unclear as what you are saying doesn't make sense. Please explain exactly what you are doing, step by step.
Rob
fabiosato
Does this equipment have a clearance volume?
Fábio Sato
hmunsell
where are your connectors? from the picture it looks like you Pipe Connector may on the other side of what ever that disk is. if the pipe has to go thru that disk to get to the connector it may cause an error.
Howard Munsell
RobDraw
rompts a warning.
I didn't look at the image as you said it doesn't have any clashes. It does. Sorry, I misunderstood your bad grammar.
Most likely, it's a clearance area that is turned off in the view.
Rob
