How to change the line style of objects underground! - Tips and Tricks
ricaun
Advisor Advisor
ricaun
I've been using Revit for some time and didn't know about this trick, so I created this video could be useful for other users.
How to change the line style of objects underground?
See yaa!
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Mirko.Jurcevic
Thank you, however, when your objects are "beyond", you cannot select more than one.
You will have this problem: https://www.engipedia.com/can-not-select-multiple-elements-in-the-plan-view/
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
ricaun
@Mirko.Jurcevic you are right I probably forgot to mention that.
Objects on this view range (beyond) cannot be select using the mouse selection box, but you can select the one object or select connected objects using 'TAB'.
