Revit MEP Forum
MEP Hidden line problem
1 REPLY 1
677 Views, 1 Reply
Hello to all,
I have a problem with the hidden line of duct.
I have set MEP SETTING like the print screen but it works just outside gap (I can not see the dash-space line for the overlapped duct).
I have tried to change the value of the line MEP Hidden but is still not working (it is always continuous).
Discipline of view is Mechanical and duct settings are not transparent.
Thank you in advance.
1 REPLY 1
debimmanager
Try this,
Kudo if you consider it and mark as a solution if it helps you solve your issue.
Thank you!!
Deivis E.
REVIT® MEP Specialist
Forma Design Contest
Technology Administrators
