Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Lookup table inconsistent units
4 REPLIES 4
DJSCRIPTS
2651 Views, 4 Replies
hello, I am trying to follow the formula I got from a youtube video in the the picture attached and circled. I did everything as he shows like this, but i am getting the error message "Inconsistent Units" when I try to do it. I am attaching my revit family, it has two csv files in it. I want the value in column A to be returned as text but I cant seem to figure it out and its driving me nuts. It looks like it should be so simple!
the formula I was using was in the WALL OPENING DIMENSIONS parameter and was: size_lookup(Lookup Table Name, "", "", ROUGH_IN KIT)
what in the world am I doing wrong?
4 REPLIES 4
talalaevd
in reply to: DJSCRIPTS
Дмитрий Талалаев
Эксперт BIM2B
Блог
Facebook | Twitter | LinkedIn
DJSCRIPTS
in reply to: talalaevd
Hello, and thank you for your response but it didnt directly answer my question, because the boolean parameter should be able to drive the text selection. I discovered that this formula below should work if I changed the header in the lookup table from RIN##OTHER## to RIN##OTHER##NUMBER
size_lookup(LookupTableName1, "", "", if(ROUGH_IN KIT, 1, 0))
but it does not and I dont know why because it should be sending a number to the lookup table, and looking up a number in that lookup table. However, for whatever reason it does not. Regardless, using some help from you, I discovered a work around by sending text to the lookup table, which I dont understand, but it works:
size_lookup(LookupTableName1, "", "", if(ROUGH_IN KIT, "1", "0"))
So hopefully this helps someone out there, and if any one can explain why exactly, feel free to chime in. thanks!
talalaevd
Beware since 18 Revit ##OTHER##NUMBER is the same ##OTHER## and ##OTHER##SOMEVALUE and it has text value. And for numer values right format is ##NUMBER##GENERAL!
Дмитрий Талалаев
Эксперт BIM2B
Блог
jmcdonell64
Thank you. I think you solved my issue.
Forma Design Contest
