Revit MEP Forum
Lookup table inconsistent units
4 REPLIES 4
DJSCRIPTS
2827 Views, 4 Replies
DJSCRIPTS
hello, I am trying to follow the formula I got from a youtube video in the the picture attached and circled. I did everything as he shows like this, but i am getting the error message "Inconsistent Units" when I try to do it. I am attaching my revit family, it has two csv files in it. I want the value in column A to be returned as text but I cant seem to figure it out and its driving me nuts. It looks like it should be so simple!
the formula I was using was in the WALL OPENING DIMENSIONS parameter and was: size_lookup(Lookup Table Name, "", "", ROUGH_IN KIT)
what in the world am I doing wrong?
4 REPLIES 4
talalaevd
in reply to: DJSCRIPTS
talalaevd
Дмитрий Талалаев
Эксперт BIM2B
Блог
Facebook | Twitter | LinkedIn
Дмитрий Талалаев
Эксперт BIM2B
Блог
DJSCRIPTS
in reply to: talalaevd
DJSCRIPTS
Hello, and thank you for your response but it didnt directly answer my question, because the boolean parameter should be able to drive the text selection. I discovered that this formula below should work if I changed the header in the lookup table from RIN##OTHER## to RIN##OTHER##NUMBER
size_lookup(LookupTableName1, "", "", if(ROUGH_IN KIT, 1, 0))
but it does not and I dont know why because it should be sending a number to the lookup table, and looking up a number in that lookup table. However, for whatever reason it does not. Regardless, using some help from you, I discovered a work around by sending text to the lookup table, which I dont understand, but it works:
size_lookup(LookupTableName1, "", "", if(ROUGH_IN KIT, "1", "0"))
So hopefully this helps someone out there, and if any one can explain why exactly, feel free to chime in. thanks!
talalaevd
talalaevd
Beware since 18 Revit ##OTHER##NUMBER is the same ##OTHER## and ##OTHER##SOMEVALUE and it has text value. And for numer values right format is ##NUMBER##GENERAL!
Дмитрий Талалаев
Эксперт BIM2B
Блог
Дмитрий Талалаев
Эксперт BIM2B
Блог
jmcdonell64
jmcdonell64
Thank you. I think you solved my issue.
