Revit MEP Forum
KEYNOTE BY PIPE SIZE
1 REPLY 1
jmendezicce
531 Views, 1 Reply
i need a insert code by keynote in system Family, like a Pipe or Duct
i need separate by size, for example:
TYPE                SIZE             CODE
PVC SDR26         6"             MT.01
PVC SDR26         4"             MT.02
PVC SDR26         2"             MT.03
thanks for help
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
Si esto ayudó a resolver su problema, recuerde "aceptar como solución" para ayudar a otros a encontrar respuestas.
1 REPLY 1
Zsolt.Varga
in reply to: jmendezicce
Hi @jmendezicce,
The challenge here is that the pipe size is an instance parameter.
Due to a limitation, the current versions of Autodesk Revit cannot add instance parameters to keynotes.
Please, vote for the following registered wish for a product enhancement here:
Keynotes with Instance Parameter Text Field
I would suggest to tag the pipes by category and defining a label which in the tag family, which reads the parameters you wish for.
I hope this information helps.
In order to point other users to the above registered wish for a product enhancement and to encourage participation on the related Revit Ideas voting, I will mark this post as a solution - your feedback or further questions or concerns are of course welcome anyways.
Please, feel free to let me know if you need further help.
Best regards,
Zsolt Varga
Technical Support Specialist
Autodesk, Inc.
Revit Ideas | Screencast | Revit Help | AKN
Forma Design Contest
Technology Administrators
