Issue While Converting Design to fabrications.
sowmiyhan
254 次查看
2 条回复
1 条消息(共 3 条)
sowmiyhan
When converting to fabrication parts. I get two issues
1.Not all parts were converted. Check the fabrication service definition.
2.The element (of type MEP Fabrication Pipework) has an open connector (at connector #1)
and also the fittings disappear while converting.
while examining the problems. For the second issue raised, it was suggested in earlier discussions to upgrade Revit. Even after updating Revit, I continue to encounter open connector issues. How can I fix both of these problems? I utilize Revit's default services for fabrication configuration.
0 个赞
已接受的解答 (1)
255 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
RSomppi
已接受的解答
I don't really have a solution for you but, AFAIK, the workflow to get this working correctly can be quite complex. You will probably need to edit the Fabrication CAD MEP database, which I am not familiar with, and have solid routing preferences with appropriate families built to manufacturing specs not just generic families when drawing the system pipe.
1. The families need a corresponding fab part in order to be converted correctly.
2. Open connectors could be coming from the original or the parts that were not converted are causing open ends.
0 个赞
3 条消息(共 3 条)
sowmiyhan
@RSomppi Thanks
