- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When converting to fabrication parts. I get two issues
1.Not all parts were converted. Check the fabrication service definition.
2.The element (of type MEP Fabrication Pipework) has an open connector (at connector #1)
and also the fittings disappear while converting.
while examining the problems. For the second issue raised, it was suggested in earlier discussions to upgrade Revit. Even after updating Revit, I continue to encounter open connector issues. How can I fix both of these problems? I utilize Revit's default services for fabrication configuration.
