Is it possible to calculate the amount of a certain floor finish in a building from using room parametres
AidanHawkins
AidanHawkins
I have a building with many rooms
Each room has a floor finish, wall finish and ceiling finish specified in the parameters.
Is it possible to calculate the total area of all the rooms that have a carpet finish for example?
A
hmunsell
How was your Floor Finish applied? Is it a floor with a finish layer set to it, Did you split face and override the surface, Did you draw a separate floor for each room....
Howard Munsell
AidanHawkins
Okay to answer your question - the actual material of the floor finish is a standard generic floor.
I am using the ´Floor finish´parameter in the Rooms identity info to identify my floor finishes..
There is no seperate floor for each room
I am trying to do it without that
Certainly. Create a room schedule, add Floor Finish and Area. Sort by Floor Finish.
lim.wendy
Hi @AidanHawkinsm,
Thanks for posting. It looks like @ToanDN  provided you with the answer to your question, so for now I am going to mark this as "Assumed Answered." This won't prevent other folks from commenting on this question though in the event other ideas come up
Remember, marking your posts as having an accepted solution really helps out other forum users that have the same issue – so don’t be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems.
If the solution did not work, you can unmark the post as an accepted solution. To cancel an accepted solution, click the ellipsis menu  > Not the Solution.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
