looking to convert rfa to dwg
simon.geerolf
simon.geerolf
hi i work with Autocad 2019 and don't have Revit. is there a way to convert this .rfa file to Dwg ?
hmunsell
if you don't have Revit, there is no way to open the RFA in AutoCAD.  if you have access to Revit you can open the RFA and Export to DWG.
Howard Munsell
dmiller_SCE
@simon.geerolf  I can convert the file to dwg for you, but I don't think it will be much help because the part in question is a duct fitting and, generally speaking, is meant to be parametric to accommodate various duct sizes. When exported to DWG, it will just become a static block.
