Revit MEP Forum
How to stop Background Processes?
69 REPLIES 69
Message 1 of 70
55914 Views, 69 Replies
Im working on a MEP model with HVAC services and I was working away and tried to save it but a message popped up and saying 'cannot save this document because duct systems are calculating' Ive found the background processes icon on the status bar to monitor them but cannot cancel them or stop them so I can save my work. very frustrating as its been doing this for over 3 hours now.
Any help would be appreciated.
69 REPLIES 69
Message 2 of 70
Matt__W
Hi, @Anonymous.Erskine You can try disabling the calculations by navigating to DUCT SYSTEMS > DUCT SYSTEM > and select a system and change its calculation option to OFF (or whichever option suits you best). You'll have to do this for each system
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 3 of 70
Hi @Anonymous,
Have you tried to disable the calculations ?
Click on one of your ducts, go to system, change type and set the calculation to "none"
GM
Message 4 of 70
in reply to: Matt__W
Thanks @Matt__W  @Anonymous
I managed to do as you suggested but the background processes were still running even though the system browser and type properties both showed that my calculations were turned off, I ended up just closing out of revit and restarting it and that seemed to work.
Thanks again
Ryan
Message 5 of 70
Matt__W
@Anonymous Great to hear! Would you mind marking this topic as solved, just so others who may have the same issue in the future can quickly find a solution?
Thanks! And I'm glad we were able to help you.
Matt Wunch
Twitter | LinkedIn
Message 6 of 70
fabiosato
Setting to performance instead of none will actually disable all calculations, none keep doing some calcs.
Fábio Sato
Message 7 of 70
cyril
Hello @Anonymous.
The answer posted by @Matt__W didn't solve your problem. Please don't mark it as solution and even the subject as solved as you didn't manage to stop background processes but only whole Revit Process.
This question is good and need a real answer. Please leave it open until we get a real answer. @fabiosato solution unfortunately didn't solve it neither in my case.
Update : I wasn't able to save or synchronise manually but somehow it manages to (auto)save after the defined time interval and synchronise when I ask Revit to close. @Anonymous was is the same for you ? If yes, your answer (what you did) is probably actually the best solution to not lose your work.
Message 8 of 70
e.gurrola
in reply to: cyril
I had the same problem. I was able to save the drawing by going to the file menu and selecting the close option to close the model. This gave me the option to save and sync with central. Stopped the background process instantly.
Message 9 of 70
in reply to: e.gurrola
File then close was the only thing that worked for me to get out of the background calculations, too.
All my systems duct and pipe are set to "None". Switching to Performance did not help.
I was only able to sync to central. My local copy was not saved.
Thanks for this suggestion!
Message 10 of 70
info
Kill Revitworker precess (task manager)
Message 11 of 70
in reply to: info
had the same problem and info's solution worked for me
thanks
Message 12 of 70
in reply to: info
This is what worked for me ^^^^^^^^^^
Message 13 of 70
Just encountered the same type of problem while editing Ducting and pipings for a Kuwaiti client. Didn't noticed the solution by info, but tried the same process by killing (Fingers crossed) the RevitWorker.exe in Windows Task Manager and it worked. Just now noticed that the solution was already provided by info. Thanks. Kudos.
Message 14 of 70
bbirge
None of the solutions worked for Revit 2018.
Message 15 of 70
in reply to: bbirge
For me, it worked in Revit 2018.
Message 16 of 70
Hello.
My solution: I searched revitwork.exe and started it. Afterwards I went back to the drawing and magically it didn't give me any more error.
Message 17 of 70
Hi. I can't find revitwork.exe for Revit 2020.1 and can't stop background process.
Message 18 of 70
Hi.
I work with revit 2019. In my case the file is located here: C:\Program
Files\Autodesk\Revit 2019
Message 19 of 70
Ehm... Sorry. The correct file name is RevitWorker.exe.
Message 20 of 70
J_Lorenc
in reply to: YarUnderoaker
I found in 2020.1 process RevitWorker.exe, but after killing it, main Revit froze completely and must kill it without saving.
Forma Design Contest
Technology Administrators
