How to Rename Group Header of Family parameter under the group parameter palette
Message 1 of 10
I am working on a Mechanical Equipment Family. Certain things in this family are optional. I have made these things optional in family by applying Yes/No parameter.
Just need to rename the Group Header of this Family parameter. I have grouped this parameter (Access Panel and Fixed Panel) under "Other" Group Header as shown in screenshot. Please suggest how can I rename or Create new Group Header.
Replies (9)
Message 2 of 10
Edit the parameter and choose a different Group.
Message 3 of 10
rudi.roux
Hi @Anonymous
Hope you are well! Smiley Happy
Kindly follow the Screenshot below which explains how to change the Family Parameter Group.
I hope this helps! Smiley Wink
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Message 4 of 10
Hi @Anonymous, I am well. Thanks & I appreciate you response.
But, I am looking forward to Change or Create New "Group Parameter", not "Select new group".
I require this new Group Parameter since there is no group parameter named as "Option" or similar to that. I was wondering if a new parameter group can be made or I can rename the existing Group Parameter's name.
Thanks in Advance!
Message 5 of 10
rudi.roux
Hi There, unfortunately not at this stage. Those are the only predefined
Parameter Groups available in Revit.
Possibly use one of the predefined groups available and workflow the
intent/purpose of those parameters with your team? Choose a logical group
which is the closest logical group for the parameters which you would like
to create.
Also, I'm 99% sure that there is a Revit Idea similar to what you require,
if not, create an idea and let's gather support for the idea so that it can
possibly form part of future Revit Roadmaps.
I hope this helps!
Rudi Roux
LinkedIn
Message 6 of 10
rudi.roux
to create.
I hope this helps!
Rudi Roux
LinkedIn
Message 7 of 10
rudi.roux
Hi @Anonymous
Apart from my previous response, herewith a link to a Revit Idea which was created by another user which can be voted up so that traction can be gained for this and possibly be considered in future releases.
Rudi Roux
LinkedIn
Message 8 of 10
Just hoping that autodesk will add this feature in the next release.
untill then, I will suffix "Optional" with the Parameter name.
Message 9 of 10
Is there any news about this topic?
Message 10 of 10
RobDraw
No news is good news.
Rob
