Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
how to edit xml file?
5 REPLIES 5
532 Views, 5 Replies
to size ducts to the correct numbers eg.(480x480 which means 500x500) i think we have to edit the xml file ! So how we can manage to do it ?
regards Rami
5 REPLIES 5
I might be misinterpreting the question, but to edit an xml file just open it in notepad, make your changes and then save it. Or you can open the xml file with the default program and click on VIEW > SOURCE to bring up the code in editable text format.
HTH,
Jon
thank you very much but still i have the same problem i did not get real sizes for ducts, what i mean is that the REVIT give me sizes like 330x330, i want to make it gives me size 350x350
KyleB_Autodesk
You can type whatever Duct size you want directly in the sizing fields in the Options bar, no need to modify the XML file here. See the attached image.
Cheers,
Kyle B
Revit MEP Product Manager
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
Kyle,
What tool did you use to create the ragged edge on the screenshot you posted?
Jose
KyleB_Autodesk
SnagIt from TechSmith.
Kyle Bernhardt
Director
Autodesk, Inc.
Forma Design Contest
Technology Administrators
