Message 1 of 18
Pls give solution for how to calculate heat and cooling load in revit 2022 version
Hi @gopigopi766
It sound like a simple question, but I am afraid that an answer can be longer than expected. For start just watch this video.
Sincerely,
EK
The heating and cooling loads tool has been dropped in version 2022.
You need to use the energy analysis tool and select the HVAC System Loads option.
This recent post might be of interest.
I want to know about heat load calculation in 2022 version . It was converted to system analysis. Step by step procedures
Pls give step by step procedure to get it
I created a spaces and zone now how to get heating and cooling loads for given spaces from system analysis
Sorry, I haven’t used it yet and have similar questions myself.
@HVAC-Novice or @Kevin.Lawson.PE might be able to assist?
Ok ,thank you.
After your spaces are placed go to the "Analyze Tab" then the "Energy Optimization" panel. Click "Generate" to generate the analysis model and then click "Systems Analysis" and run the "HVAC Systems Loads and Sizing" workflow.
You'll get a nice loads report and you can make a schedule of Analytical Spaces with the calculated load parameter.
@Kevin.Lawson.PE can you please clarify though if there is a relationship between Spaces placed by the user and Analytical Spaces created when the energy model is generated?
Do we still need to create Spaces first and fill the whole model volume with Spaces including voids, shafts, plenums etc or does the energy model creation process work that out itself?
Should or shouldn’t we tick the Perimeter Zone option?
I’ve only used the energy analysis tool a couple of times so please forgive these rudimentary questions.
Thanks for that, clarifies things a lot.
Only a couple of points that I would come back on -
@ceyhunyuzuak You make a very valid point. I have been experiencing the same isues and it is BS that the newly calculated heatloads are not reflected in the space properties..... Have you found a workaround since?
You can reactivate the legacy Heating and Cooling Loads tool by editing your revit.ini file:
About the Revit.ini file:
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-FE24D0A5-4603-41A5-BACB-4122993AFA6A
Misc settings in the Revit.ini file (including turning on the H&C Loads Analysis):
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-B01A6B07-4FF2-4115-8B61-1274FAF9CC91
The helpful tip that led me to this discovery (thanks Autodesk help docs!)
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-2DD2759D-3E3A-4AE7-BB37-0DF53981591E
As I said in part 14
