Cable tray - Change offset with an angle different to 90°
ovidiu.serbanXXEKR
Observer Observer
ovidiu.serbanXXEKR
Observer
Observer
Hello!
There are situations when I need to change the elevation of a cable tray by a small value (ex: 5cm / 2 inches) and in this value I cannot fit two 90° elbows. How can I change this vertical fitting angle to another value (ex: 30°)?
I know I can do this from an elevation view, but that is not very convenient. I would like to do this while I'm drafting from the plan view.
Thank you very much for your time!
johna
You can use fabrication parts or use the add-in called MEP up/down.
__________________
Criticize but don't hate
iainsavage
Try the video attached.
Let me know if it doesn't work for you.
