Heat and cooling load in revit 2022
gopigopi766
Message 1 of 18
gopigopi766
Pls give solution for how to calculate heat and cooling load in revit 2022 version
Replies (17)
Message 2 of 18
evgeny.kurbatov
Hi @gopigopi766
It sound like a simple question, but I am afraid that an answer can be longer than expected. For start just watch this video
Sincerely,
EK
Message 3 of 18
iainsavage
The heating and cooling loads tool has been dropped in version 2022.
You need to use the energy analysis tool and select the HVAC System Loads option.
This recent post might be of interest.
https://forums.autodesk.com/t5/revit-mep-forum/what-is-the-difference-between-havc-load-calculation-...
Message 4 of 18
gopigopi766
I want to know about heat load calculation in 2022 version . It was converted to system analysis. Step by step procedures
Message 5 of 18
gopigopi766
Pls give step  by step procedure to get it
Message 6 of 18
gopigopi766
I created a spaces and zone now how to get heating and cooling loads for given spaces from system analysis
Message 7 of 18
iainsavage
Sorry, I haven’t used it yet and have similar questions myself.
@HVAC-Novice or @Kevin.Lawson.PE might be able to assist?
Message 8 of 18
gopigopi766
Ok ,thank you.
Message 9 of 18
Kevin.Lawson.PE
After your spaces are placed go to the "Analyze Tab" then the "Energy Optimization" panel.  Click "Generate" to generate the analysis model and then click "Systems Analysis" and run the "HVAC Systems Loads and Sizing" workflow.
You'll get a nice loads report and you can make a schedule of Analytical Spaces with the calculated load parameter.
-Kevin Lawson, PE
www.rippleengineeringsoftware.com
Revit heating and cooling load calculations in one click!
Message 10 of 18
iainsavage
@Kevin.Lawson.PE can you please clarify though if there is a relationship between Spaces placed by the user and Analytical Spaces created when the energy model is generated?
Do we still need to create Spaces first and fill the whole model volume with Spaces including voids, shafts, plenums etc or does the energy model creation process work that out itself?
Should or shouldn’t we tick the Perimeter Zone option?
I’ve only used the energy analysis tool a couple of times so please forgive these rudimentary questions.
Message 11 of 18
iainsavage
Thanks for that, clarifies things a lot.
Only a couple of points that I would come back on -
  1. sliver spaces have to conform to certain geometric constraints, in particular they have to have opposing walls which are parallel to one another so any other shafts which don’t conform did have to be filled by Spaces, or their walls made non-bounding, for the heating & cooling loads tool to work.properly. Quotes from Autodesk help: “Sliver Spaces are narrow areas bounded by parallel interior room-bounding components.” and “It is critical to the heating and cooling loads analysis to account for the entire building volume. This includes areas that exist as cavities, shafts, and chases
  2. In the energy analysis tool do the analytical spaces pass load information back to the corresponding user-placed Spaces? When I tried to use the tool there didn’t seem to be any relationship between the two, even in terms of space names but I had concluded that I was doing it wrong and I haven’t had time to go back and investigate it further.
Message 12 of 18
Kevin.Lawson.PE
  1. Yes, you are correct, but I haven't had any problems with sliver spaces.   If you do have an oddly shaped shaft you can add a space to it.
  2. No, the Analytical Spaces do not pass information back into the Spaces.  Only Spaces pass information to Analytical Spaces.  It's important to note that this only happens when the Analytical Model is regenerated, so make sure you regenerate the model before running the loads.
-Kevin Lawson, PE
Message 13 of 18
ceyhunyuzuak
I appreciate it calculates loads with ease, it even takes shading elements and soil faced elements into the account as it hsould be, however Number 2. seems to be a great problem as:
1. analytical spaces can't read parameters defined in Family elements, which is a game changer problem for me since I can't list and filter those parameters in Analytical Space Schedules as I used to easily do in Space Schedules to size heating and cooling elements based on the calculations.
2. we can't place space tags that displays Heating Loads and Cooling Loads or similar values because there is no such thing as Analytical Space tag.
I can't see any practicle way to workaround those issues. Under such circumstances as a HVACR Engineer I can say that Revit 2022 will drop value of my work quite a bit. guess I will stick to 2020 for now. I don't know what I will do with my customers who use 2022, though.
Message 15 of 18
cristina.sanzJFMPA
Observer
Observer
@ceyhunyuzuak You make a very valid point. I have been experiencing the same isues and it is BS that the newly calculated heatloads are not reflected in the space properties..... Have you found a workaround since?
Message 16 of 18
sdcartmell
You can reactivate the legacy Heating and Cooling Loads tool by editing your revit.ini file:
About the Revit.ini file:
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-FE24D0A5-4603-41A5-BACB-4122993AFA6A
Misc settings in the Revit.ini file (including turning on the H&C Loads Analysis):
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-B01A6B07-4FF2-4115-8B61-1274FAF9CC91
The helpful tip that led me to this discovery (thanks Autodesk help docs!)
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-2DD2759D-3E3A-4AE7-BB37-0DF53981591E
Message 17 of 18
iainsavage
As I said in part 14
Message 18 of 18
sdcartmell
Great! Good on ya
