Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Hatch like Lines on pipe fittings
22 REPLIES 22
Message 1 of 23
Robert_Jansen_TBX
2176 Views, 22 Replies
For some strange reason I am having  hatch lines on the pipe fittings.
It is not something that comes from the Family, because all fittings have the same issue.
What could the reason be.
Thank you in advance,
Robert
22 REPLIES 22
Message 21 of 23
Hi Francisco,
Thank you for your reply. Adding a fitting from another file has the same effect. So I agree that it is a setting somewhere in the template. But finding it .........
Message 22 of 23
It is definitely in your system colour scheme.
When you change the scheme to None, the colours AND the pattern disappear.
Message 23 of 23
I know this reply is a little late, but hopefully it can still help somebody. We had the same problem, and after seemingly endless troubleshooting we solved it. You need to go to color schemes, from the architecture tab to the dropdown menu in the rooms panel. Then uncheck visibility for the desired piping systems.
Forma Design Contest
Technology Administrators
