For some strange reason I am having hatch lines on the pipe fittings.
It is not something that comes from the Family, because all fittings have the same issue.
What could the reason be.
Thank you in advance,
Robert
Robert
Hi Francisco,
Thank you for your reply. Adding a fitting from another file has the same effect. So I agree that it is a setting somewhere in the template. But finding it .........
Hi Francisco,
It is definitely in your system colour scheme.
When you change the scheme to None, the colours AND the pattern disappear.
I know this reply is a little late, but hopefully it can still help somebody. We had the same problem, and after seemingly endless troubleshooting we solved it. You need to go to color schemes, from the architecture tab to the dropdown menu in the rooms panel. Then uncheck visibility for the desired piping systems.
