Revit MEP Forum
Flexible duct view
10 REPLIES 10
Message 1 of 11
7665 Views, 10 Replies
Flexible duct view
Dear all
am attaching a picture with this question
on the left i connected a diffuser to a duct with flexible
on the left is my drawing, as you can see the connection is like lines | | | | | |
on the right side is another drawing, as you can see it is showing full flexible detail
can this be done ? and how ?
regards
10 REPLIES 10
Message 2 of 11
abulla
There's an option in your flex duct properties to change the line style, pick the "Flex" style (once you pick Flex it will remember your selection and default to that).
Message 3 of 11
in reply to: abulla
thanks for the fast answer, it worked
but as another question, as in the pic i uploaded, the view of the flex duct looks narrow and better, when i choose Flex or Flex 2, the looking for the it is not "pretty"
can i chahne the look of the flex or flex 2 view ?
Message 4 of 11
CoreyDaun
I don't believe that the appearance of the Flexible Duct Patterns is customizable.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 5 of 11
in reply to: CoreyDaun
seems to be
as in the pic as it seems the guy used "rectangle" flex duct !!
Message 6 of 11
CoreyDaun
Looking at the majority of the Flex Duct in the right image, it looks like the Flex Duct Pattern "Flex 2". Note that the appearance of this pattern is affected by the View's scale, so maybe that's making it look strange. The image below depict two differing scale Views of the same section of Flex Duct. Does this seem like the difference you're seeing?
Message 7 of 11
Is it possible to have the same type of appearance show up in section view?
Message 8 of 11
debdipm
How to make geometry of flex duct visible here?
Message 9 of 11
tawilson
Is your detail level set to fine?
Message 10 of 11
apjones
in reply to: debdipm
It looks like the duct may be too short. Try moving the VAV box and see if it appears.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
Message 11 of 11
robert2JCCH
The bend is too extreme for the size of flex duct (in-field you'd be crushing a compressed flex duct to make this fit). Change elevations or pull the box further away from the trunk.
Forma Design Contest
