Family not visible in plan view
tmccar
Advisor Advisor
Message 1 of 10
tmccar
I have created a family from a sat file, which is classed as a a mechanical item, and I have inserted in the project. It is visible in an elevation, but not in a plan view.
I have many other families which are the same type which are visible in a plan view also, but not this one family.
Why would this one be invisible?
Replies (9)
Message 2 of 10
rudi.roux
Hi @tmccar
There are quite a few possibilities as to why this would happen. Is you Mechanical Equipment turned on for that view under your Visibility/Graphics Overrides (VV or VG)? You're sure that the family was set to the Mechanical Equipment Category? Is the View Range set to the correct heights etc.?
You're welcome share the family or images of your view along with Project Pallet information or VG information. Sending the family will be a quicker route.
Hope this helps.
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Message 3 of 10
tmccar
Yes, mechanical equipment is turned on because there are many other mechanical items visible.
View range is set to unlimited in both directions.
Message 4 of 10
kadmonkee
confirm that when you are in the family editor, select the elements in your elevation, or 3d view they are turned on in your Plan / RCP  and set for each Detail Level in the Family  Element Visibility Settings
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 5 of 10
tmccar
In the family editor, I can see the item in the "Ref Level". But in the Front and Left view, it is invisible.
Message 6 of 10
kadmonkee
while in the family Editor go to a 3d view select everything right click and select Visibility.
depending how the family was created, check all the boxes until you get the display you want.
see previous posted image
if possible could you share the family so others can investigate
thank you
Message 7 of 10
tmccar
It's not visible in 3D, and there's practically nothing to click anyway.
(See file attached)
Message 8 of 10
kadmonkee
ok I see it now.the issue is the imported symbol needs to be exploded to expose the line work and mass extrusions
thank you
Message 9 of 10
tmccar
When it's exploded, it loses a large part of it.
Message 10 of 10
kadmonkee
unfortunately that may be a result of the source it was imported from
it can be used as a base to get you started and fine tuned afterwards.
thank you
