Revit MEP Forum
Electrical Outlet Symbols not correct
4 REPLIES 4
infoBN8KX
309 Views, 4 Replies
infoBN8KX
Has anyone else experienced the issue of the electrical outlet symbol not showing up correctly on a power plan? How do I make the symbol show up properly? See my screenshot.
4 REPLIES 4
Tom_Kunsman
in reply to: infoBN8KX
Tom_Kunsman
It seems like this plan is set to a Medium level of detail. Usually Annotation Symbols are set to only show at a Course Level of Detail.
Check your level of detail and or View Template and see if changing it to a Course level shows the symbols.
If you do want your plans at a Medium level, then you will need to update your families for this.
infoBN8KX
in reply to: Tom_Kunsman
infoBN8KX
@Tom_Kunsman, i do have it at a course level.
fabiosato
fabiosato
Can you share the outlet family for checking?
Fábio Sato
Fábio Sato
RSomppi
RSomppi
Does the same family work as expected in other views/projects.
It appears that the family may not be set-up to show the annotation symbol properly.
The detail level could also be overwritten in the V/G settings.
For a direct answer, share a model that exhibits the behavior.
