Has anyone else experienced the issue of the electrical outlet symbol not showing up correctly on a power plan? How do I make the symbol show up properly? See my screenshot.
It seems like this plan is set to a Medium level of detail. Usually Annotation Symbols are set to only show at a Course Level of Detail.
Check your level of detail and or View Template and see if changing it to a Course level shows the symbols.
If you do want your plans at a Medium level, then you will need to update your families for this.
Can you share the outlet family for checking?
Fábio Sato
@infoBN8KX wrote:Has anyone else experienced the issue of the electrical outlet symbol not showing up correctly on a power plan? How do I make the symbol show up properly? See my screenshot.
Does the same family work as expected in other views/projects.
It appears that the family may not be set-up to show the annotation symbol properly.
The detail level could also be overwritten in the V/G settings.
For a direct answer, share a model that exhibits the behavior.
