Drawing a decorative pendant Light
jlambert
jlambert
I am trying to create a pendant light fixture that has a decorative iron frame around the shade. I am having trouble trying to create this design. Any help would be appreciated. An just so you know I am new to revit and still learning things. I have attached a pic of the light I am trying to create.
Unless there's a compelling reason for including that detail level (ie, renderings to be used for marketing), I'd strongly advise using the most generic shape/hanger combination you can find and sizing it appropriately.  Leave the fancy visual graphic stuff to the architects.  The attached file should get you what you need - just adjust the height and diameter of the extrusion and pendant length, then link the .ies file you're using.
