Revit MEP Forum
Dimmension split while inserting
4 REPLIES 4
andkal
236 Views, 4 Replies
Hello
When I place the dimmension between two objects and accidentally snap to some other line that Revit finds, the dimmension is then split into two. Is there any method to turn this option off?
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
4 REPLIES 4
BiMBoXiT
in reply to: andkal
Hi
while adding dimension 1 first reference - 2 Second reference point and 3rd click should be outside
this is what I'm doing it. I hope you happy about my answer.
BiM BoXiT
andkal
in reply to: BiMBoXiT
I usually do it as you showed, but it doesnt matter where you click the third time actually.
When you click somewhere outside, the dimmensions also split when revit finds something (even hidden).
So I just have to be careful, but putting more attention to make it more precise makes my work less efficient.
• Autodesk AppStore
iainsavage
in reply to: andkal
Yes I agree its annoying.
I can’t test it just now but there’s a setting in the Snaps dialogue for “snap to remote objects” which you can disable but I don’t know if it affects dimensioning.
You can also type SO as a running override to disable snaps whilst executing another command.
BiMBoXiT
in reply to: andkal
Yes it is a meter! when /where you clicking the the third point, it should not be on an object
Joy of Revit !!!
BiM BoXiT
Forma Design Contest
Technology Administrators
