different pipe types
Hello every one
I have some questions
I have transferred pipe types from an UK template  to  a metric   one but when i change pipe segment in routing preferences , the size list wont change for drawing a pipe  .what should i do ?
how about transferred pipe fittings  ,should i change their lookup tables ?
does anyone have different pipe types in us metric template ?
sujanc
You need to use the option transfer project standards for that and select pipe size, duct size and other relevant data to transfer from your UK template to current one. Hope this will work.
Please select "Accept solution" if the information was helpful (This allows other users with the same issues to find it higher in search results), or reply back if you need more help!
