Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
3D view shows only wireframe
4 REPLIES 4
550 Views, 4 Replies
Hello, hope you can help me guys!
I'm new to this autodesk product, so I don't know much about it.
The problem is, that in 3D view, I can see architecture only as a wireframe (as shown below).
Is there a way to fix this problem? Or is this a problem, that should fix an architect?
Tags (2)
4 REPLIES 4
sujanc
Check the visual style of your revit and change it to shaded from the bottom left corner. See the snap fro reference.Visual style.jpg
Please select "Accept solution" if the information was helpful (This allows other users with the same issues to find it higher in search results), or reply back if you need more help!
in reply to: sujanc
Thanks for reply!
I tried this option before, but it still draws wireframe above all visual styles.
NimeshJ
Hello @Anonymous ,
Looks like Architecture file is an issue.
This happens when we convert rvt file into ifc and then again opening in revit.
in reply to: NimeshJ
Thanks for reply,
I also thought, that this might be an Architecture file issue.
I tried load an IFC and RVT architecture files, but both in my project shows 3D model as seen on pictures.
But if you open separately IFC or RVT architecture file, then in 3D it shows everything correctly.
I also tried to purge my project, and that didn't help
Forma Design Contest
