- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a design model which I am attempting to convert to a LOD 350 duct model for coordination. I have exported the design model, opened it in Fabrication CAD MEP, then sent the .maj file back to revit. I open it up in revit it all comes together as it should.
When I try to change the Insulation Specification to a 2" Insulation or any insulation for that matter I do not see any changes in the model. If I manually place a piece of Fabrication duct and add insulation it shows up.
I am using the same Database between Revit and FabCAD. I've tried it with Revit MEP Imperial Content V2.1 and Imperial Content V3.05. I am using Revit 2018 and FabCAD 2018. I added a new insulation specification and reloaded the database in Revit to make sure I was using the same one.
I've checked to make sure my MEP Fab Insulation layer was turned on in Visibility Graphics. I've created the model in a completely new Revit Project and nothing?
Any help would be appreciated.
