How can i create one Local file from two central file in Revit MEP.
phanduykhanh
Observer Observer
phanduykhanh
Observer
Observer
How can i create one Local file from two central file in Revit MEP.Capture.PNG I can syns data from a local file to two central file?
ennujozlagam
no you can't .one local file one central file.
nope.
sksaifali99
First of all open both the central model by checkingOPEN.JPG "DETACH FROM CENTRAL" and select the option "DETACH AND DISCARD WORKSET" option while opening the file and save both the files separately. Now you'll be having two separate local file.
Now open a single local file. Link the another file into that open file then select the BIND.JPG"BIND" option from ribbon. Now see you linked model became the entity of your present open local file as a group. Then ungroup the model and remove link.
Now you'll be having both of your model into a single model.
s.borello
You can't... Revit doesn't work this way.
johna
You cant, you create your own central then link two central file and then you create your local from you central. if that makes sense
__________________
Criticize but don't hate
