Custom MEP Specific Angles
mwagnerfrey6
1,456 次查看
12 条回复
1 条消息(共 13 条)
mwagnerfrey6
Why on Earth can we not create custom specific angle preferences in MEP settings? Or at the very least, why isn't 15deg an option?
0 个赞
已接受的解答 (2)
1,457 次查看
12 条回复
回复 (12)
2 条消息(共 13 条)
hmunsell
Have you considered putting that in as an Idea in the Revit Ideas Forum
Howard Munsell
0 个赞
3 条消息(共 13 条)
nmarcelis
Hi @mwagnerfrey6
Yes this is possible.
See the article below on how to do it.
Model pipe elbow at angles less than 5 degrees in Revit (autodesk.com)
Revit Certified Professional Architecture, Structure and MEP.
0 个赞
4 条消息(共 13 条)
iainsavage
已接受的解答
I think they have set them at what would traditionally be commercially available elbow angles but you can also use the "any angle" option then set the preferred snap angles in the general settings:
5 条消息(共 13 条)
HVAC-Novice
已接受的解答
For duct and pipe routing?
If the below doesn't solve it, please make clear what angles you mean and what you want to accomplish.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
6 条消息(共 13 条)
iainsavage
They want to add to or change the list of angles in that "Use specific angles" list.
7 条消息(共 13 条)
mwagnerfrey6
@hmunsell  So it can be ignored? Haha. I did a search to see if this was posted on the forums and I thought it included the ideas as well. I guess I was mistaken, cause this was posted as an idea:
More Specific Routing Preferences
@iainsavage While I don't consider your work-around an acceptable solution and think Autodesk needs to fix this, I'll mark it as the solution because it's not your fault lol.
If anyone comes across this page and thinks we should be able to add custom angles to the preferences, please go vote at the link above.
0 个赞
8 条消息(共 13 条)
iainsavage
I don't know what your experience of Revit is but if you reject so-called "workarounds" you're going to have a hard time going forward.
Very few Ideas result in any action by Autodesk and there are issues from 2007 still unresolved.
So you can either use "workarounds" or wait years (or possibly for ever) for your wishes to be implemented.
Good Luck!
PS: You maybe marked the wrong post as solution?
9 条消息(共 13 条)
revitPWC6K
I cannot admit that this is an acceptable solution. When you have set angles in this window for snaps,
anyway the routing solutions still has halucinations and creates angles of fittings which do not exist.
0 个赞
10 条消息(共 13 条)
RSomppi
Not sure why using a settings dialog box is not an acceptable solution so I'm guessing you are talking about something else.
Do you have a specific question about the settings?
0 个赞
11 条消息(共 13 条)
iainsavage
First, I didn't say that its a solution, it is a workaround as stated earlier.
Secondly it does work if you set the snap increments correctly, allow the pipe to snap to the angle before releasing the mouse button and the elbow families allow those angles.
Please provide examples of it not working and maybe someone can help you with your specific problem.
12 条消息(共 13 条)
Bryantsummers
Community Visitor
Community Visitor
I want to use the "use specific angles" options on my project, but I want to add options for 10 and 15 degrees. Why is this not possible?! Easy code issue!!!
0 个赞
13 条消息(共 13 条)
RSomppi
We users cannot answer your question/suggestion.
You can request new features in the Ideas forum.
0 个赞
